Clutch plate?
Old Dec 29, 2009 | 06:08 PM
Todd R's Avatar
Todd R
Clutch plate?
My son and I were getting firewood today. I had chains on and he did not. He got stuck and I hooked up a tow strap. ufortunatly he had his truck in reverse. I hammered and hammered on it utill I got an asbestos smell then I was basicly in nutral. I am assuming I burnt out the clutch plate. This is an 86 150 with the straight six. I am wondering how hard this is to change and how expensive. (provided I can get it out of the feild)
Thank you for your help. Todd.
Old Dec 29, 2009 | 06:15 PM
greyghost85's Avatar
greyghost85
well, it can actually be fun. in a heated garage with all the proper tools, and a good repair manual. i am doing it with only the repair manual.....wahhhh!
Old Dec 30, 2009 | 09:46 AM
Todd R's Avatar
Todd R
There will be no heated garage. It may have to be done in a picked bean feild on a steep incline in the snow. unless I can find a way to pull dead wheight 150 yards uphill through crusty snow with no acces to a tractor.
Old Dec 30, 2009 | 10:30 AM
Todd R's Avatar
Todd R
I was just pricing clutch plates. Is it worth paying the extra money for the performance part? This is a work truck, it spends a lot of time hauling firewood and working in snow. I should have a plow on it next year. Also as long as I am in there what other parts should I be changing.
Thanks again, Todd
Old Dec 30, 2009 | 11:43 AM
6fifty_f1fifty's Avatar
6fifty_f1fifty
I was going to say check if your rear main seal is leaking but the heck with doing that in a field...
I just replaced mine a few weeks ago, not to easy on an incline. A tranny jack makes everything easier but if you cant use one of those, I would make a 2x4 stucture inside the cab, remove the transmission hump and use a come-a-long or something like that to hold the tranny up. Cast iron ones a heavy as crap, the aluminum srod isn't to hard to manhandle by yourself but for safety's sake I wouldn't do it in your predicament.
I didn't know there were performance ones, I looked at local auto stores and there were only two options 10" and 11" mine used a 10, works great now.
Old Dec 30, 2009 | 12:27 PM
Todd R's Avatar
Todd R
Thanks for the input. The 2x4 frame is a great idea. I can get a tranny jack but I may use both considering the conditions.
I thought about the rear end at first, but a few years back I had the rear end on my 87 go out. I locked in the front and drove about 200 miles in front wheel drive. I did not even know you could do that untill the guy at the tranny shop sugested it. But right now I have nothing going to the front or the back.
O'reileys has a few different options in performance kits. But considering I am layed off I think I will just have to go with the standard.
Thanks again for your help,
Todd.
Old Dec 30, 2009 | 12:53 PM
greyghost85
you're gonna get the kit with the throw out bearing and pilot bushing, right?
Old Dec 30, 2009 | 12:57 PM
Todd R's Avatar
Todd R
I think it has everything I will double check.
Old Dec 30, 2009 | 12:58 PM
f100jim's Avatar
f100jim
It is a good bet that you burned up the clutch disk. It is also a good bet that you trashed the flywheel and pressure plate. You will need to check them. The flywheel may need to be resurfaced, the pressure plate may need to be replaced.
It is neither easy nor safe to do the job on the side of a snow covered hill. I would find a way to pull it back to the garage if at all possible. If it were me, I would GLADLY pay a tow truck driver $150 or more to pull it out of there and drop it in my driveway. That would be money well spent.
Old Dec 30, 2009 | 01:10 PM
Todd R's Avatar
Todd R
It does not list the parts but I think it is all there. I have not done this since like '95. And that was a two wheel drive.
Product Images
Thanks Todd.
Old Dec 30, 2009 | 01:23 PM
Todd R's Avatar
Todd R
The problem is it is too far off the road. Where I live we only have one or two towing companies and I don't think they will touch it where it is. We were pushing our luck by driving down there but we heat with wood and are about out. We thought with two trucks we would be able to pull it off, oops...
I see your point about danger and dificulty but I may not have a choice.
Thank you for the advice about the fly wheel I had not considered that.
Thanks, Todd.
