Cam sensor?
Old Dec 30, 2009 | 10:38 PM
rweber's Avatar
rweber
have the same problem with a 95--on highway dies, no fuel pressure--replaced pump --will start for 3-5 min's then die--check fuel bowl-low ?
Old Jan 1, 2010 | 08:14 AM
dmptrkr's Avatar
dmptrkr
creteman79: Check wiring harness connection at IPR and also connector on passenger side of fuel bowl. Might have bent a pin or something when reconnected after fuel pump replacement.
rweber: If fuel bowl is low you might have a broken pickup tube in tank. Have you tried switching tanks?
CatchersDad97
57
Jun 7, 2013 03:17 PM
SpikesHD
13
Sep 17, 2012 10:21 PM
pkm
34
Dec 9, 2011 02:45 AM
stevorino
Aug 16, 2007 01:47 PM
dr9999
57
Nov 27, 2005 05:25 PM
