ac clutch issues
Old Dec 29, 2009 | 02:09 PM
andyman91's Avatar
andyman91
ac clutch issues
i am trying to remove the ac clutch but i cant fiqure out what size bolt and how to pull it off.
Old Dec 29, 2009 | 03:47 PM
Hitokori's Avatar
Hitokori
Ford Mustang A/C Compressor Clutch this is for a mustang but the a/c compressor is a a/c compressor i dont think their is a difference
hope this helps u out
Old Dec 29, 2009 | 07:05 PM
zxwut?'s Avatar
zxwut?
What truck do you have! Mine is a 95 f250 with a 460. Remove the screw in the middle and slide off the outer plate. Then unplug the plug at the back. I had to remove the fan shroud to get it out of the way and then. use a 3 jaw puller to yank the pulley off. It's been several months since I did it but I think there might have been a snap ring on the shaft somewhere holding something on but maybe not? Once you take the outer plate off, it should be pretty obvious if there is anything else on the shaft though. It was a major pita for me because everything had basically melted together. I had a catastrophic type failure of mine
KaeGee
Feb 26, 2015 09:06 AM
dalberti
Sep 16, 2013 10:58 AM
PastorPaul
May 6, 2011 09:44 PM
RTM
Jul 16, 2009 04:15 PM
dllt
1983 - 2012 Ranger & B-Series
Jan 5, 2007 08:14 AM
