strange code this morning
Old Dec 29, 2009 | 06:55 AM
bakerbuilttracks's Avatar
bakerbuilttracks
well it was 31 last night not too cold but cold. so i woke up and started my truck bout 10 min befor i left the house. all seemed good and for some reason i did a dtc check on the way in. i got an edge evo and it allows me to do it while driving. i got a really strange one. P0232 Fuel Pump Secondary Circuit High. i have never seen this before. i replaced the pump bout a year or more back. what would cause this to show up, and should i be worried. the truck seems to run ok. i have limited internet access at the momet and will check back at lunch or later this evening. put ur heads together and let me know. thanks fte
Old Dec 29, 2009 | 07:05 AM
robs01f250's Avatar
robs01f250
I would clear the code and see if it comes back,
Old Dec 29, 2009 | 07:26 AM
Kwikkordead's Avatar
Kwikkordead
Have you cleared the codes since you replaced that fuel pump last year?
That code means the circuit is open (pump disconnected, broken wire, worn out brushes, etc).
Old Dec 31, 2009 | 02:10 PM
bakerbuilttracks
hey sorry bout my late reply i have had really limited access to the internet the past few days. when the code came up i wrote it down and cleared all codes and it hasent shown up agian i have checked it every day. so whats the cause of it comming up. like i said i replaced the pump a year or more ago and have cleared the codes many times since then. should i be looking out for something to fail?????
Skylercs
Modular V10 (6.8l)
Mar 11, 2013 04:56 PM
Skylercs
Mar 1, 2013 11:37 AM
fenix1
Jan 27, 2013 05:45 PM
fenix1
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jan 27, 2013 05:42 PM
fenix1
Bronco II
Jan 27, 2013 05:41 PM
