Does this indicate water pump problem???
Old Dec 28, 2009 | 11:17 PM
Enduroman's Avatar
Enduroman
I remember reading on this forum that a leak from this little pipe indicates an impending Water Pump failure. I've searched and can't find that thread again. I changed the pump a year ago after it seized and installed an aftermarket pump that appeared to work great. I've only put 1300 miles on it since. Now it is starting to leak out if this little pipe when i start it up. Not alot, but enough to mess up the driveway. I got another new pump from the same parts store (identical to the one that's in there - reluctantly) that i intend to put in tomorrow and they say they'll give me my $$ back for the first one. Before I tear it apart again I was hoping someone could tell me for sure that a leak from that pipe means a bad pump. After tomorrow, i don't know when i'll have a chance to do this again. Thank you!
Old Dec 28, 2009 | 11:21 PM
big poppa's Avatar
big poppa
Thats the fuel drain valve tube, if you have a leak out of there, it should smell like fuel, not coolant.
Old Dec 28, 2009 | 11:23 PM
mueckster's Avatar
mueckster
A leak from that pipe means your fuel bowl drain valve O-rings are leaking.
Easy fix: http://www.guzzle7pt3.com/fdrain.php
Old Dec 28, 2009 | 11:33 PM
Bigcat350's Avatar
Bigcat350
You need 2 #202 Viton O-rings and 1 #013 Viton oring to fix that or you can buy a kit or the whole valve assy. The orings and 1 hour will fix it for about $1.50 its not hard to do.
Old Dec 29, 2009 | 12:31 AM
Enduroman's Avatar
Enduroman
Well I'm glad I posted here before tearing out a perfectly good water pump! Just checked again and sure enough, whats coming out of that tube is diesel. There's a few drops of antifreeze on the lower Rad hose, and dangling from the steering arm that made me think everything wet down there was antifreeze. I'll have to get a little dirtier tomorrow to find out where that's coming from. In the meantime, looks like i'm doing some O-rings tomorrow. Thanks for the link to the Guzzle page. Looks great.
Old Dec 29, 2009 | 12:35 AM
big poppa's Avatar
big poppa
As for the coolant, check around your thermostat housing, if yours is stock, they rust and form leaks over time. Let us know if thats your problem because Dieselsite has a nice aluminum replacement.
Old Dec 29, 2009 | 12:37 AM
Bigcat350's Avatar
Bigcat350
Your Pic is what helped every one figure out the problem. Good Job and Guzzle can fix you up.
Old Dec 31, 2009 | 10:32 AM
Enduroman's Avatar
Enduroman
I pulled those O-rings, thinking that I could get some from Ford and get rolling. They wanted to sell me a kit of 5 O-rings for the fuel filter bowl for about $85!!!! No thanks. I called Guzzle and the six dollar, better quality ones (apparently) are on the way. In the meantime, to get the truck out of the garage while the new O-rings make their way here (make be a while to cross border), Guzzle recommended just turning the old leaky O-rings around. Worked great. No leaks so far. Once i get 'em switched, I'll give it a wash and find where the few drops of antifreeze are coming from.
Old Jan 11, 2010 | 11:00 AM
Enduroman's Avatar
Enduroman
Fuel filter bowl fitting
new O-rings arrived here in BC, Canada in just 8 days, over New Years! I was prepared to wait much longer. Thank you Guzzle for shiping so fast. Installed them yesterday and they're working great. Thanks again folks for keeping me from replacing my water pump!!!!
When replacing the O-rings i noticed another deteriorating seal on a metal hose coming from the side of the fuel bowl, with a red marking on it. (see photo) The metal line itself is also quite loose, as opposed to the line next to it that is very secure. I'm reluctant to pull its fitting until i have the right parts. Will I be calling Guzzle bob again?? Any advice is appreciated, as always.
Old Jan 11, 2010 | 11:23 AM
big poppa's Avatar
big poppa
Looks like the fuel sleeve let go, degenerated. What I would do is order the Mechanics kit, for 58.00-66.00 US dollars you can't go wrong, everything is in the kit for the engine and fuel, no running around and waiting.. Bob and Clay sell those sleeves individually if you just wanted to go that route.
Old Jan 11, 2010 | 01:16 PM
Enduroman's Avatar
Enduroman
What exactly are those two lines?
Old Jan 11, 2010 | 01:45 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
those are fuel lines from the filter to the heads......
