390 to 302
Old Mar 15, 2000 | 09:19 AM
BB's Avatar
BB
390 to 302
Old Mar 15, 2000 | 11:39 AM
66Jeff's Avatar
66Jeff
390 to 302
I have a 66 f100 now with a 390 3spd in it. I would like to put a 302 with a 5spd in it's place. How much work will this take? Is there something to convert my existing clutch to a cable clutch on the 5spd? If the project becomes to large I will stick with the 390 and rebuild it.
Old Mar 15, 2000 | 04:36 PM
jowilker's Avatar
jowilker
390 to 302
Rebuild the 390 and be happy, the work will over whelm you.
John
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
Old Mar 15, 2000 | 05:11 PM
66Jeff's Avatar
66Jeff
390 to 302
Thanks for the input.It was just a thought.Next thing is the 3 spd is not cutting it on the highway. What manual tranny should I look for that has a good OD.
Old Mar 15, 2000 | 06:30 PM
jowilker's Avatar
jowilker
390 to 302
Man you like beating your head against a wall. Put a 275 rear gear in and save the work.
John
66 F100s
Old Mar 15, 2000 | 10:45 PM
BigBrownTruck's Avatar
BigBrownTruck
390 to 302
I am starting to see solutions to the modern clutch linkage dilemma. Windsor Fox is making some conversion bracketry. Forte Transmission is selling modern 5sp like T5 with vintage style bellhousings. If you peruse SuperFord or Mustangs and Fords, you will see some of these new products. I imagine that this stuff might get pretty pricey however. There is a 4sp (3+OD) that came out in F series (as well as vans) in 78. My 79 F150 has one, and a work truck (E150) I drove in the early 80's had one. It is not a toploader style shifter but uses linkages on the side of the tranny like your 3sp. I know there weren't any 390's in 78 but I have seen this tranny bolted to a 400. I don't know for sure but I would think that the tranny to bellhousing bolt pattern in this era might be common. If the bolt holes line up, and the input shaft of the tranny is the right length, maybe this would work. I'd say that rebuilding the 390 and using the 2:75 axle is probably the most cost effective solution. Of coarse if you found a carburated Mustang 5.0 w/ 5sp for cheap....... I have both a 390 and a 302 and I'd love to get the 390 rebuilt.
BBT
Old Mar 16, 2000 | 07:20 AM
William's Avatar
William
390 to 302
I saw an advertisement some time ago, for a hydraulic throw out bearing. Looked like a regular throw out bearing with two hydraulic lines (braided steel) attached. Seems like a good way to eliminate most clutch linkage? Sorry I don't have the magazine handy. It most likely would have been in Classic Trucks or Mustangs and Fast Fords.
