I removed the fuse panel to try and search for my door entry code..
There was an aftermarket speaker underthere blocking my vision..
I assumed it was part of the motorolla handsfree phone stuff that was removed before I bought the truck.. I cut the two-wire speaker wire..
After realizing it was part of the alarm system to re-soldered the wire's back..
This really make's no sense.. I have no heat up front.. The ENTIRE control cluster seems to work properly including the blower..
But it make's no heat up front.. While there is still plenty in the rear !.
I can control the temp up front on the display .. Or so it says... 65-90..
just took a quick glance at the Alldata files for that vehicle. looks like there is a blend door motor that controls the mixing of the warm and cold air ... my guess is you accidently disconnected a wire going to that motor... not sure exactly where that motor is located other than it is probably under the inside passanger compartment
give me a PM with your email addy and ill send you a word doc with a bigger image
