93 explorer driver side power window
Old Dec 28, 2009 | 08:55 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
I just switched doors from my 91 and put it onto the 93. The window did work when it was on the 91 but doesn't now on the 93. I think it may be the switch but need to know how the power going into the switch, or which wires should have power into and out of the switch to determine if it is the switch. This is just for my yard plow rig so if it is a bad switch I might jut put some sort of toggle switch to replace it, thanks.
