514 big block
Old Mar 9, 2000 | 01:49 AM
mocky's Avatar
mocky
514 big block
Old Mar 15, 2000 | 03:45 PM
BL69 FORD's Avatar
BL69 FORD
514 big block
I am worried about traction. Would bigger tires help I have 245's now and were could i put some extra weight. also its equiped with a dana 60 with a 4.10 gear ratio. Its going in a 69 f250 curently 300 6
Old Mar 15, 2000 | 04:55 PM
mattb's Avatar
mattb
514 big block
bigger tires will help to a point then they will rub and blow up. if you go too big. for more weight dont add weight just move around what you already have on the truck.
i mounted a fuel cell in my bed right abovethe rear axle. and moved the battery back there too. just some suggestions
mattb
Old Mar 15, 2000 | 08:42 PM
ummduh's Avatar
ummduh
514 big block
Just remember that cubic inches is NOT the same as pounds. A 514 shouldn't weigh much more (if at all)than a cast iron headed 460. Just run the proper springs for a 460 and you should be fine.
Old Mar 18, 2000 | 01:44 AM
mocky's Avatar
mocky
514 big block
with 514 cubic inches under the hood, if your only two wheel drive, rear traction is probably out of the question. bet she's fun in the rain, huh. big motors, ya gotta love'em
Old Mar 18, 2000 | 01:50 AM
mocky's Avatar
mocky
514 big block
i have a 71 and i run a 275/60/15 on the rear, no problem with clearing the fender wells. you might get a 295/50/15 in there but not sure, this would be wider and not really taller than your 245's.
