87 or 92 octane??
Old Dec 27, 2009 | 11:58 AM
amkkba's Avatar
amkkba
87 or 92 octane??
Do you notice any difference in MPG when running on different octanes? I also have a shop in town that sells 24% ethanol blend and when I put that in my suburban it got better mpg especially when towing. Anyone use ethanol blends?
Old Dec 27, 2009 | 04:24 PM
Monsta's Avatar
Monsta
Sit. Stay.
There are only really two reasons why you should get better mileage while using a gasoline with an octane rating above 87.
1. The engine is in a poor state of tune which causes knock with the 87 octane which pulls down timing or...
2. The fuel is not actually the advertised octane due to age.
Higher octane fuel does not have more energy or BTUs than lower octane fuel.
Using 24% ethanol fuel will damage fuel system components. 10% is the maximum that should be used safely.
Old Dec 27, 2009 | 04:47 PM
Gale Hawkins's Avatar
Gale Hawkins
I have not tested the difference with the 1989 429 4v but the 1992 454 TBI (in a MH)will gain enough mileage (power) to make 91 Shell V Power the same cost as Shell 87. The power is nice in the hills. In the newer vehicles I can not see better mileage with higher octane. Not sure the logic that enables this with the 454. It may advance timing until a knock is detected.
Old Dec 27, 2009 | 06:33 PM
Monsta's Avatar
Monsta
Sit. Stay.
That 454 cannot advance its timing. Only retard it.
Old Dec 27, 2009 | 08:01 PM
sddesigns's Avatar
sddesigns
FTE Leadership Emeritus
FTE Emeritus
...LOL
Old Dec 27, 2009 | 08:08 PM
cando's Avatar
cando
I had a 84 one ton dually dump with a plow, It didnt matter what it got for gas; mileage was horrible, lots of grunt though!
I found that running the mid grade fuel in my wifes hemi pwrd dog, it got just slightly better mileage. So I spend the extra 2 to 5 dollars per tank for the midgrade gas.
Old Dec 28, 2009 | 12:37 AM
Monsta's Avatar
Monsta
Sit. Stay.
Steve, my post wasn't a joke.
Even current PCM tuning cannot increase timing due to fuel type (hence the need for a tuner) so surely a 1992 OBDI isn't going to be able to. That 454 runs better with higher octane due reason #1.
Cando, the advertised HP for your wife's HEMI is from using 89 octane. Makes sense you'd see a decrease in performance using a lower grade fuel.
Old Dec 28, 2009 | 07:24 AM
sddesigns's Avatar
sddesigns
FTE Emeritus
Pleonasm, it is ......
Big-Red-Lariat
2004 - 2008 F150
17
Jun 5, 2010 07:56 PM
mrad
Jan 26, 2010 08:28 PM
gdoggy
1983 - 2012 Ranger & B-Series
Jul 15, 2005 02:38 AM
krewat
Modular V10 (6.8l)
49
Jun 16, 2005 05:06 PM
Rockledge
Oil & Lubrication
86
Dec 4, 2003 10:45 AM
