nice write up and a very nice idea for a quick fix...but if there a 1/4" aluminum,,,that means you have a 2 1/2" inlet for air flow..thats not much more air then the early 99.....how are the EGT's????
Originally Posted by mueckster
IIRC, they are more like 1/8'' thick. I saw a set that hadn't been installed at our GTG on Oct at Pete's in CT. Jim (rat49f6) had a set from Clay with some new oem plenums.
Actually they expand the stock plenum as you insert them since the stockers are actually rolled in at the top. There is only a .164" difference between stock and the inserts in internal diameter.
Originally Posted by Stewart_H
Hopefully Clay will make that an option, to keep the cost down.
We only offer them anodized, but it adds very little to the purchase price since we do them in large bulk orders and combine with other parts as well. Bottom line, if it would save you money we would definately make it an option.
I just ordered a set of these (along with a DP Tuner!!). I'm not sure that I have a leak, but it's almost guaranteed to happen due to the design. Once again, Clay has come up with a simple, effective, quality solution.
