C4 Transmission
Old Mar 24, 2000 | 07:16 PM
78f100_1's Avatar
78f100_1
C4 Transmission
The actuating rod between the inner manual lever and the parking pawl has separated in the center causing the trans to lock in park. I removed the tail extention housing and disengaged the pawl but I can't get to the actuating rod to reconnect it. My plan for now is to remove the rear part of the actuating assembly that engages the pawl leaving the forward part of the actuating rod still entact. I need to know if there is any chance that the remaining part of the actuating rod could interfere with the valve body or any other part of the transmission while it's operating?
Old Mar 24, 2000 | 09:30 PM
hollibau's Avatar
hollibau
C4 Transmission
