Engaging 4 wheel drive
Old Dec 26, 2009 | 08:21 AM
amkkba's Avatar
amkkba
I just purchased my 05 Ex and got to use it this morning during our first blizzard of the season. I had it in 2 wheel in the garage and put it in 4 wheel before backing out but it did not engage (light on dash did not come on and I continued to slip). I drove forward again thinking it would engage but nothing. I put it back to 2 wheel and then put it in neutral and back to 4 wheel and then it engaged. The hubs are set on auto.
Is this how the Ex is suppose to work? I did not expect the delay for the 4 wheel to engage or do I need to get it serviced??
Old Dec 26, 2009 | 09:19 AM
Snuffy2000's Avatar
Snuffy2000
That's NOT how it should work. You should not need to shift to neutral to engage 4X4. I would shift in/out of 4X4 a few more times to see if it does the same thing. Also, listen for the electric motor that is physically engaging 4X4 at the transfer case - you should be able to hear it. Maybe it was just stiff from lack of use? If the symptoms persist, you may want to have it looked at.
Steve
Old Dec 26, 2009 | 12:26 PM
kev03's Avatar
kev03
[I]f you put it in 4 wheel low that is how it works!
Old Dec 26, 2009 | 12:49 PM
amkkba's Avatar
amkkba
Originally Posted by kev03
[i]f you put it in 4 wheel low that is how it works!
That is what I thought.
kevin remillard
1997 - 2003 F150
Apr 15, 2014 06:11 PM
FordLou
1997 - 2003 F150
25
Dec 23, 2010 01:00 AM
kbodge
May 24, 2005 11:57 PM
handyman43358
May 22, 2005 03:52 PM
