dead truck
Old Dec 26, 2009 | 05:27 AM
jiggersup's Avatar
jiggersup
Unhappy dead truck
ok, i had to boost my truck yesterday (~35 degs) because i din't plug it in... once started, i idled it for a bit, and then my truck shut down and would not start again.... the glow plug light does not even come on now when i try a start. what to do, what to do....
Old Dec 26, 2009 | 05:37 AM
CPUNeck's Avatar
CPUNeck
Check fuse #30 IIRC... should be PCM/Fuel bowl heater. If it's blown, unplug the plug at the rear of your fuel filter housing that is toward the driverside. (It'll be fine to drive that way) then replace the fuse, and enjoy the rest of your holiday!
That is the rear of your filter housing (pay no attention to all the crap that's different on mine) The plug is in the left on the photo, under the braided fuel line, and has NOTHING plugged in.
Old Dec 26, 2009 | 05:46 AM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
If it is #30 as CPUNeck says (it very likely is) and it blows again, your fuel bowl heater is shot. You'll have a few options:
1) unplug it and leave it that won't - won't harm a thing
2) order a new one and replace the dead one
3) take it out of the fuel bowl and just call it good
start at unplugging it, pick one of the 3 above as your permanent fix, and you're all done!
Let us know what it was and how you fixed it please. It helps when others join & find your thread for there to be a conclusion.
Old Dec 27, 2009 | 12:07 PM
jiggersup's Avatar
jiggersup
That did it!!! thank you very, very, much
