1983 ford Header Problum
Old Dec 25, 2009 | 08:46 PM
edicken2003's Avatar
edicken2003
got a 1983 ford and i drop a 351 m in it. well the header 1 seems too long it goes below the frame???? have a 3 or 4" body lift on it
Old Dec 25, 2009 | 09:10 PM
70converter's Avatar
70converter
what motor was in it originally? if it was a 300 L6 you probably need to stiffen up the front end with 3/4 ton springs and shocks. Had to upgrade mine when i went to a 400 cleveland.
Old Dec 25, 2009 | 09:41 PM
Franklin2's Avatar
Franklin2
Headers usually do hang down low, since there is no other way to run the exhaust, especially on the driver's side. The factory ran their crossover pipe neatly behind the oil pan. There is no way a long tube header can do that. You will have to come out of the header and go under the frame on the driver's side, or curve it under the tranny pan and go over to the pass side.
