my motor took in water and mud . i took out spark plugs cranked it over for a minute there wasn't much water my oil wasn't milky did two oil changes but motor turns over really slow it was running hot when i took in water .
what should i do ???it a brand new 5L 302 with 4000 km
try some wd 40 in the cylinders be generous with the wd in there and without the plugs in there crank it over.. you may have bent some valves or push rods or even worse a connecting rod if it was revving hi , replace the plugs. also check water is not in your distributor check the plugs and wires along and points. accidents happen so nobody's judging anyone :/
and on additional note idk about the breathers on the tank water may have gotten in to one or both so if its not starting that could definitely be a culprit and if you find it is flush the gas out put fresh gas and change the fuel filter
