04 Ex 4x4 Code P1828
Old Dec 22, 2009 | 09:28 PM
dlibson's Avatar
dlibson
P1828-t/case counter clockwise shift relay coil circuit malfunction.
I have this code. Did the simple and replaced the T-Case motor. No change. Checked all fuses...
Any thoughts?
2004 5.4 automatic.
Old Nov 4, 2019 | 02:42 PM
The Guy's Avatar
The Guy
I'm getting the same code and did the basic checks as well. Did you ever figure out what was causing this code?
Old May 26, 2022 | 05:12 PM
peterniez's Avatar
peterniez
2nd Gear
Hello, I have both the P1828 and P1820 codes... were you guys able to fix your problem? Can you share what you guys found to be the problem? Thanks
olyellow
Feb 4, 2019 06:22 PM
j4brug
2004 - 2008 F150
May 29, 2006 08:43 PM
