water leaks
I have a 2004 expedition Eddie Bauer 2wd i am having some leak issues i have cleaned the front sunroof drains dose any one know if their is rear drains? also i am getting a wet spot about the size of a basket ball under the front passenger floor mat not on top nor is it wet any where else i thought it was the ac drain but wouldn't it be wet on the front part of the carpet coming from under the dash? please help i hope i posted in the right spot i am new to this thanks Michael
I suggest that you position yourself so you can see up under your dash and have someone hose from the sunroof forward including all of the sides if the windshield to see if you can find the source of the leak.
