4X4 won't disengage
4X4 won't disengage
1996 f150 standard cab long box with floor shift 4X4 and 5 speed manual transmission and 5.0 engine.
i don't know how to disengage the 4X4 on this truck. its stuck in LO 4X4 and i can't get it out. i want it in 4X4 HI. it has the auto hubs in the front so i assume i just move the lever on the floor to the desired position but its not moving. what do i do?
need answers quick. gotta move the truck out of the appartment parking lot before it gets towed with the snow on the ground. they gotta plow...
If you need to move it, I don't know you don't just get in and move it. Does the truck not move in 4lo?
It has to be in neutral to shift between 4lo and 4hi. If you have it in neutral, then it might be binding. Drive it back and forth a little bit and try it again. If it's stuck then try some penetrating oil on the linkage and don't neglect it. The linkage needs a bit of TLC a couple times a year, especially where they use salt on the roads.
what ever it is its stuck like nothing else. i had the clutch pushed in and the shifter in neutral position but the floor shifter don't move. do i need to shut the truck off for it to shift or not?
its not that i can drive it, i just need to be able to go faster then 15 mph so i can bring it home for the weekend
on
this may help....i dont even have the floor shift hooked up to the transfer case.. just go below do what u got to do to detcah the floor shifter then just tap the lever on the trans case towards the back of the truck with ur hand or lightly with a hammer all the way back is 2 wheel 4 hi is the next click from 2 wheel towards the front of the truck. it is a pain in the *** to get it to stop just right on 4 hi without it going to neutral but it may take a few tries no biggie. i found the best way is to pull it towards 4 hi with my hand and just b4 its gonna go i just tap it with a ratchet still maintaining pressure from my hand. otherwise it goes right thru 4 h into neutral. just do what i wrote ull b allset
im kinda having the same prob with my 91 f150 4wd,the front end is free but the rear end acts like its 4wd still any body got any ideas,the 4wd drive has been used 3 times in the past year and its never been beat up or taken in the mud,i went up a steep six foot incline got out unlocked the hubs and put it in to 2wd and acted like it was in 4wd lo in the rear end,took it home and found that some wires had got wrapped around the 4wd drive line and ripped,had them fixed but it still acts like its locked up in the rear,is their a fuse or relay ?
I put it in drive and it took off fine the it started actn up again i took the 4wd shaft out,all this happened after the wires ripped even after they were fixed its still doin it it goes in to all gears fine just wont go in to 2wd,on the 4wd shaft side of the transfer case it spins free, ive checked all the linkage and its all good just tryn to figure out why the rear end is locked up
TheMechanicalAnimal
34
12-07-2016 10:22 AM
78 Short Box 460 4x4
01-19-2013 09:05 PM
thomastl
2009 - 2014 F150
07-27-2011 04:07 AM
jackpiner57
1997 - 2003 F150
03-02-2010 11:51 AM
