brake problem
Old Apr 8, 2000 | 01:14 AM
FORDTRUCKMAN1976's Avatar
FORDTRUCKMAN1976
brake problem
a buddy of mine , is having problems getting the master cylinder to work correctly on his truck. he has a 1978 F150 4x4, that he recently flipped. he is now rebuilding it using the body from a 1979 F150 4x2. he has just replaced the master cylinder, now when the pedal is pressed he can only get fluid to come out of the rear resivoir. when he bench bled the cylinder fluid came out of both resivoirs. I'm not sure which truck the brake booster is from, and I'm assuming he bought the master cylinder for the 4x4. what is causing this? Also the truck doesn't run yet, would this have any effect on it?
Old Apr 8, 2000 | 05:48 AM
jowilker's Avatar
jowilker
brake problem
FT76, One thing he might try, is adjusting out the rod going from the booster to the MC. MCs can be quirky don't give up yet.
John
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
Old Apr 8, 2000 | 12:20 PM
mk's Avatar
mk
brake problem
It's also possible the cups might be bad in the m/cylinder, even if it's a rebuild. This happened to me just a couple of months ago when I did the brakes on my 68.
Old Apr 8, 2000 | 12:45 PM
Stoney's Avatar
Stoney
brake problem
U-HIGH75
Aug 19, 2012 06:25 PM
Ford or nothin
Oct 30, 2010 02:35 AM
cj091184
1983 - 2012 Ranger & B-Series
Jan 3, 2007 01:43 AM
muely
May 31, 2004 12:52 AM
jevans
28
Jan 1, 2004 11:55 PM
