Sponsored by: Real Truck
Adjustable Track bar with leveling kit
Old Dec 21, 2009 | 05:15 PM
ajordan193's Avatar
ajordan193
I'm trying to re-center my front axle after installing a Rize 2 inch leveling kit on my 06. After looking into the two track bars available they both require more than 3 inches of lift because they will hit the front differential. Suggestions?
05-07 Ford F250/F350 Super Duty Adjustable Track Bar:eBay Motors (item 290382917033 end time Jan-17-10 09:47:42 PST)
05-09 Ford F250/F350 Super Duty Adjustable Track Bar:eBay Motors (item 330378915288 end time Dec-19-09 11:49:42 PST)
Old Dec 21, 2009 | 11:04 PM
DAVE67FD's Avatar
DAVE67FD
In many applications a track bar is only required with 3" or greater lift. Try using a "Drop Bracket" instead. These are typically more intended for the 0-3" lift issues. A few are available but think the Readylift track bar is the best choice considering it's strength, OEM specifications as well as offering it as a kit with the extended bump stop brackets and rear carrier bearing spacer. Unfortunately i don't believe it is available as a seperate piece if you don't need the other items.
Old Dec 21, 2009 | 11:07 PM
DAVE67FD's Avatar
DAVE67FD
Sorry,
forgot to post you the link.
readylift ford f250 f350 super duty track bar relocation bracket
Old Dec 22, 2009 | 10:21 AM
ajordan193's Avatar
ajordan193
Thank you, i just purchased the bracket.
montana_highboy
Mar 25, 2011 03:42 AM
daytomann
Jan 18, 2011 04:35 PM
buzzflood
1947 and Older Ford Trucks
Dec 8, 2010 10:26 AM
twinpeaks
22
Feb 4, 2010 06:56 PM
jdneal88
Jan 22, 2010 07:46 AM
