lift kits?
Old Dec 21, 2009 | 02:58 PM
dieselkid's Avatar
dieselkid
lift kits?
iv been looking around and i cant find anything for the 84... i want to get a lift kit and then get some 35's but i cant find a 4inch lift anywere, infact i cant find a liftkit in anysize... who sells these for a 84?
yes i know i can get 35's under it stock but i would like to have a 4in lift... will i need to get my steering extended and all that stuff like jeeps have to do when they lift 4in??? or will it be ok with none of that death wobble stuff?
Old Dec 21, 2009 | 03:24 PM
84 f250 6.9's Avatar
84 f250 6.9
pretty sure that suspensionconnection.com and jackit.com have 4" susp. lifts and 2-3 body lifts
Old Dec 21, 2009 | 03:26 PM
joe f350's Avatar
joe f350
here the 4 inch u been looking for
Ford F250 Lift Kit 1980-1996 4x4 truck -4" Kits by Tuff Country Suspension
Old Dec 21, 2009 | 08:11 PM
Links56's Avatar
Links56
Hey I found a lift kit for $15.
4x4x16 #2 SOUTHERN YELLOW PINE TREATED
Old Dec 21, 2009 | 11:03 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Sorry, 17.97 now, price went up 3 dollars since you posted that.
Lift kits for IFS front axles are not cheap, but that is the only way to lift them and get decent tire mileage.
Old Dec 21, 2009 | 11:54 PM
starmilt's Avatar
starmilt
Buying a decent lift for a ttb frontend would shure cut the price of a D 60 swap.
Old Dec 22, 2009 | 01:35 AM
joe f350's Avatar
joe f350
the d60 in my areas are about 1200 the kits about 900
Old Dec 22, 2009 | 01:57 AM
starmilt's Avatar
starmilt
Well do the math 4inch lift 900
D60 st 1200 automaticaly get 2 inches 1200.
You get a D60 for 300 bucks.
Old Dec 22, 2009 | 02:12 AM
joe f350's Avatar
joe f350
a dana 60 for 300 where i think u may have just lost it old man
Old Dec 22, 2009 | 10:07 AM
starmilt's Avatar
starmilt
Do the math if you are going to spend 900 on a lift anyway and you can get a D 60 for 1200, then you can have a D60 for 300 extra. It makes a cheap D60 upgrade.
Old Dec 22, 2009 | 10:09 PM
Dave Sponaugle
And 35" tires on a Dana 44 is going to be pushing it rather hard.
I would hate to spend 900 on a lift only to find out the axle can't handle the tires that are also not going to be cheap.
In that instance, go with the 60 and settle for a bit smaller tires and in the long run, even money with a much more dependable axle.
Old Dec 24, 2009 | 11:05 AM
dieselkid's Avatar
dieselkid
heres the thing my truck aint a 4x4, i was looking at the suspention today and i could just get a 4in bigger spring or a 4in plate to lift my spring, get a longer shock or 2 and extend the (idk wut the arm is called, but the arm that goes from the frame and hold thelower mont for the shock) by some metal and cut making it an inch or 2ish longer and i should be good on the front end.... now the back is were it gets tricky, kinda stilling workign outhow to raise.. maybe get a 4in spacer between the differental and the spring....
had a jeep cheeroke with a 4in block spacer and it worked just fine, and it would be the cheapist way... considering i dont do tomuch offroading it wouldnt be that big of a deal to have a block susptention lift
Old Dec 24, 2009 | 11:11 AM
Links56's Avatar
Links56
I posted the wood post! Just undo all the body mounts and slip a 4x4 between the body and the frame. Then get some longer body mount bolts. I use treated wood whenever I do it. Do the same to the bed. I wood should last just as good and if it doesn't then if you still have the truck in 20 years replace the wood with new.
Old Dec 24, 2009 | 11:54 AM
starmilt's Avatar
starmilt
LMOA talk about a hillbilly lift. lol I at least use oak no treated pine for me no sir.
Old Dec 24, 2009 | 12:29 PM
dieselkid's Avatar
dieselkid
does the steering geomitry change when u go 4ins??? do i need longer steering arms??? how hard is it to actually get the cab lifted off the frame?
