6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
2010 programer?
Old Dec 21, 2009 | 02:06 PM
hopperwagonbob's Avatar
hopperwagonbob
2010 programer?
does anyone have one for the 2010 6.4 yet? called edge an they said they were not done testing yet. my brother has a 2008 and said it took care of his problems and added 2mpg. dont have any problems yet but would like the 2mpg. thanks.
Old Dec 21, 2009 | 02:31 PM
hopperwagonbob
what is dpf delete ? had 2000 7.3 before. this emission stuff is all new for me. i am a farmer from indiana. no emission police around here that i have heard of anyway. thanks.
Old Dec 21, 2009 | 05:45 PM
senix's Avatar
senix
DPF delete is an off road application. Diesel Particulate Filter (DPF) is used to trap the soot an oil burner makes.
In order to get rid of it you need to re-program and PCM (power control module).
So a programmer capable of going around the programming for cleaning the DPF is necessary.
Old Dec 21, 2009 | 06:58 PM
hopperwagonbob
thanks im learning. found sparten from nc ordered 210 programer and the delete pipe. slowly getting it now. thanks to this site.
Old Dec 21, 2009 | 07:11 PM
senix's Avatar
senix
just be aware that you will need to return it to stock if you need to take the truck in for service.
Here is a good link for you :Powerstroke 6.4L Bible Page
Old Dec 21, 2009 | 07:38 PM
hopperwagonbob
yea they told me that i would need to take pipe back off . i will do all my own service work . and i had a 2000 f350 7.3 for 9 years i bought new and never hard any warrenty work done. thanks
Old Dec 21, 2009 | 07:44 PM
senix's Avatar
senix
suggest you get the truck broke it before you put the extra power to it first though..It is a lot more than what you are used to in a stock form.
Old Dec 22, 2009 | 06:54 AM
capt caper's Avatar
capt caper
I don't understand why someone would spend the money for the tuner,dpf delete pipe and take a chance on warrenty work. I figured the cost of fuel savings by going that route and figured it would take years to break even. This was when fuel was $ 4.50 gal.
One would have to put on alot of mileage each year to warrent this. Enlighten me if I'm wrong.
Old Dec 22, 2009 | 06:58 AM
senix's Avatar
senix
If the goal is fuel saving alone then you are correct. It would take years.
In the ops case, he is a farmer so I can understand his need right away.
In my case I did it to give it a little power, run a tad more effiecent and because I could. Will I ever recoup my cost, maybe or maybe not. Not a concern to me.
Old Dec 22, 2009 | 08:57 AM
R-T0r21on's Avatar
R-T0r21on
If you're gunna burn all that fuel anyway, you may as well have the power too. Once you do it, it'll be like the V-8 commercials ( slap your forehead ) and think "why didn't I do this sooner"? Fuel savings is only part of it. It's efficiency and "fun factor" as well.
Old Dec 24, 2009 | 06:21 AM
hopperwagonbob
How many miles should I wait? Own several new deere tractors and they say just take it easy the first day then work it hard .thanks
Old Dec 24, 2009 | 06:24 AM
capt caper's Avatar
capt caper
I got plenty of power stock..I get speeding tickets all the time and I'm going thru my $1200 Michelins fast.
Old Dec 24, 2009 | 06:40 AM
senix's Avatar
senix
I beleive the manual says the first 1K don't tow and don't do any WOT, vary the rpms.
Mine was a 500 miles break in being an 08. So I think I would follow that as long as you can stand it.
Then I am of the opinion, drive it just like you have always done with diesels and it will serve you better.
Ever stand beside one that was used correctly and one that was used for groceries? then you know what I mean.
Old Dec 24, 2009 | 08:11 AM
hopperwagonbob
Won't be doing any towing or wot this winter .just easy road miles till spring.just the fun factor I guess.
Old Dec 24, 2009 | 06:02 PM
caprang's Avatar
caprang
I wouldnt want the DPF on a farm either(not that I like it on the road either but such is life). If you take the truck in the fields with 1,400 EGT's youre bound to set your field on fire.
Aside from that the benefits of deleting the DPF are better MPG, better performance, less fuel in the oil, lower EGT's, and if youre not working the truck hard (like those of us that dont tow in the winter) the truck starts to run like crap as you fill the DPF and fail to get a really hot regen.
Other than the warranty concern I cant find a down side to removing it. Just wish I had the balz to do it
