Sponsored by: Real Truck
codes
Old Dec 21, 2009 | 12:41 PM
bohiaa's Avatar
bohiaa
codes
hay all,
2000 F250 SD 4X4 throwing a po174 & 171
Too lean bank 2 & 1
this leaves a lot to check
can anyone guide me in the right direction ?
Old Dec 21, 2009 | 02:10 PM
Monster-4's Avatar
Monster-4
I take you have a gas engine? Most common problem when getting these codes is a vacuum leak at the PCV line going into the TB. There is a 90 degree elbow that likes to crack.
Old Dec 21, 2009 | 02:54 PM
bohiaa's Avatar
bohiaa
Ok will check this out. Yes it's a gasser the 10 cyl, " guess I forgot to include that little tid-bit of info"
Thanks a million
Old Dec 21, 2009 | 06:57 PM
fordtech08's Avatar
fordtech08
also check your maf, alot of people like to use Krap&Nasty air filters covered in oil that makes your maf read wrong( you get oil cover the wires so it doesn't see all the air that goes by it) even with out the filters they can get dirty
