thermostat
Old Dec 21, 2009 | 07:19 AM
damicofuel's Avatar
damicofuel
thermostat
I need to replace my thermostat, and had seen some post about using a hotter thermostat. What arre advantages, and what is a part number.
Old Dec 21, 2009 | 07:40 AM
riverrat41's Avatar
riverrat41
I have read here lately that many are staying with the 195 stat.Some have gone to the 203 but not syre if all are happy with it....I guess it depends on where you live....Others will give there .02 soon.Good luck
Might look into a Billet Housing(Dieselsite) for the stat.The factory ones tend to leak or form a pin hole.
Old Dec 21, 2009 | 08:29 AM
damicofuel's Avatar
damicofuel
thanks for input, the 195 is readily available
Old Dec 21, 2009 | 08:37 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Here is the 203* stat. Make sure you get the long shaft stat. LINK.
Here is the billet housing. LINK
Old Dec 21, 2009 | 08:53 AM
mueckster's Avatar
mueckster
I was one of the ones who changed back from the 203* to the 195* t-stat. I was having some engine oil temps that were a bit too high in the summer. All is good now. I have a 203* t-stat from DS. If any one wants it, PM me. I won't be going back to one.
Old Dec 21, 2009 | 09:08 AM
riverrat41's Avatar
riverrat41
Roland...I knew I remembered reading it but could not remember who had trouble.Too many posts read.
Old Dec 21, 2009 | 09:28 AM
damons's Avatar
damons
I live in Washington State, I just replaced mine yesterday, with the 195, my truck is running much better with it.
Old Dec 21, 2009 | 12:38 PM
PaysonPSD's Avatar
PaysonPSD
I'm going back to a 195° stat. Have it just haven't installed yet.
Basically what Roland said, the hotter the t-stat the hotter the oil.
Old Dec 21, 2009 | 12:40 PM
aklim's Avatar
aklim
Supposedly it helps the motor run better. Have I noticed any performance or mpg improvement? Not yet.
Old Dec 21, 2009 | 02:23 PM
DND58's Avatar
DND58
Also going back to 195° stat. I'm convinced my fan clutch engaged more often while pulling passes last summer.
Old Dec 21, 2009 | 03:14 PM
big poppa's Avatar
big poppa
I might switch back to the 192, (Fords new suggested thermostat) in the summer, it cold as heck and I like how toasty it is in the cab.
Old Dec 21, 2009 | 03:28 PM
aklim's Avatar
aklim
I can't say it has made any difference as to how toasty the cab is. It MIGHT heat up a little faster but not so fast that you'd notice, IMO
Old Dec 21, 2009 | 04:29 PM
big poppa's Avatar
big poppa
I can feel it, definetly hotter after warmup. Not so much how faster it warms as far as I can tell. I wished I would have used my produce thermometer in the vents with the 195* versus the 203*. Maybe with the switchback this coming spring.
