Modular V10 (6.8l)
ehaust manifold stud torque?
Old Dec 20, 2009 | 08:33 PM
mattd17's Avatar
mattd17
hi all, i am just looking for a quick piece of info. i just got done with changing exhaust manifold studs and nuts on an 02 v-10... by the way, what a major PITA !!! anyhow, i am looking for the torque spec for the nuts, and if there is a specific torque sequence pattern?
sorry, but i dont have a manual for this truck.
thanks in advance!
Old Dec 20, 2009 | 09:00 PM
Rugby3's Avatar
Rugby3
The nuts are torques to 18 Ft lbs and the studs should be 89-115 inch lbs. The sequence is starting on the rear top bolt then to the bottom then back to the top working your way forward top to bottom.
Old Dec 21, 2009 | 12:04 AM
mattd17's Avatar
mattd17
thanks for the quick response. i was also wondering if you knew the torque for the studs holding the manifolds to the Y pipe"
Thanks again for your help!!!
Old Dec 21, 2009 | 05:20 AM
Rugby3's Avatar
Rugby3
I didn't see one in the book for connection to the Y pipe and I think that is a simple "tight" feel for those.
F-250 WARHORSE
35
Oct 16, 2025 08:45 PM
rdmobile
Modular V10 (6.8l)
May 11, 2020 10:42 PM
griff1455
Modular V8 (4.6L, 5.4L)
Nov 10, 2015 06:13 PM
78Southwind
Dec 16, 2009 05:12 PM
