help! ring gear stuck
Old Apr 8, 2000 | 10:04 PM
jbhf250's Avatar
jbhf250
Old Apr 10, 2000 | 10:39 AM
Abbey's Avatar
Abbey
Well...my ford threw its ring gear from its
flexplate. So I need to take the transmission
down and bolt on a new flexplate. Problem is, the
ring gear is lodged up against the transmission bellhousing, so I cant turn the engine to unbolt
the converter from the flexplate.
My first thoughts are to get a crowbar and try
to pry the ring gear away from bellhousing so I can turn the engine. Is this dangerous? I dont
know if Id be applying too much force against the
crank (and Id be prying from the edge of the flywheel, meaning the force would be coming from one side).
If prying that thing is unsafe, is there anything
else I can do to get my transmission away from the
flexplate far enough that I could change the flexplate?
ANY help would be appreciated.
-Abbey
Old Apr 10, 2000 | 01:01 PM
fordmando's Avatar
fordmando
Maybe remove the rear tranny mount, and loosen the engine mounts enough so you can tip the engine back a little (and disconnect the exhaust so it won;t han up. Now you should be able to remove the tranny and leave the converter hooked up to the engine. (Pull tranny straight back until it clears the torque converter.) Now you should be able to get the ring gear off, and take the converter off.
fordmando
78 F-150 4x4 400 4 on floor
86 Nissan 300ZX
George
Old Apr 10, 2000 | 02:16 PM
FORDTRUCKMAN1976's Avatar
FORDTRUCKMAN1976
If your careful, you can unbolt the bellhousing and slide the trans back leaving the converter bolted to the engine. A good transmission jack will help
Old Apr 10, 2000 | 04:24 PM
StockMan's Avatar
StockMan
[FONT COLOR="#0000ff" FACE="Tahoma"]Wow what a dilemma! I've never seen that happen. I think the suggestions to date are helpful. The only thing I'd add is that the ring gear is brittle. Therefore, it shouldn't take much force to get it to snap if you decide to pry on it. Oh yeah–MAKE SURE YOU WEAR EYE PROTECTION! Good luck. :-)[/FONT]
http://www.dealerconnection.com/DealerConnection/Themes/Standard/Ford/lgo-ford.gif
[FONT COLOR="#ff0000" SIZE=" 2" FACE="Bassett"]Stock Man[/FONT]
[FONT COLOR="#0000ff" SIZE="-2" FACE="Tahoma"]
1967 F-250 FE 390 4wd LWB Styleside
1966 F-250 I6 240 2wd LWB Flareside
http://www.hometown.aol.com/tbeeee
Old Apr 10, 2000 | 04:33 PM
Nathan's Avatar
Nathan
How about whackin it with a cold chisel. That way you avoid breakin somethin you dont want to!
Nathan
Old Apr 13, 2000 | 08:49 PM
bar5516's Avatar
bar5516
a # 2 buckshot in a 3 1/2 inch twelve gauge works great..... hahahahaha
seriously (without the bud light talking) undo your tranny bolts, and tranny mounts, and crossmember. use a jack to steady the
motor. and tie a chain to your tranny tailhousing, then hook it on the 4-wheeler (or equivalent), seriously i had to do that on a threespeed. and pull if you break something go the the local junk yard and buy another...
66'f100 460, blower, &nitrous
i dont drive too fast, i just fly too low!
