Sponsored by: Real Truck
2003 5.4L Quits
Old Dec 20, 2009 | 08:14 PM
Planenut99's Avatar
Planenut99
2003 5.4L Quits
Hello all, I'm a newbie looking for some help. I have a 2003 F350 crew cab with a 5.4L.
Occasionally, when you stop, the truck idles slightly low and quits when you attempt to accelerate.
I have changed the fuel & air filters, installed new spark plugs, replaced one bad spark plug boot, cleaned the mass airflow sensor, cleaned the throttle plate, checked the fuel pressure, and verified the system voltage.
The truck has not set any codes or pending codes. I called and spoke with a tech at the local Ford dealer and he has one in the shop with the same problem. They had replaced an idle air control and the truck came back. He is stumped as well. (my competitive side would love to figure it out first!)
Anyone have any ideas?
Thanks in advance!!
Jeff
Old Dec 20, 2009 | 09:14 PM
ReAX's Avatar
ReAX
Have you cleaned the IAC or DPFE valve? IAC or other vacuum leak would be my top suspects.
Old Dec 20, 2009 | 09:24 PM
aphotic26's Avatar
aphotic26
Check the hose that connects to the PCV to the back of the throttle body it will most likely have a foam sleave, you can slip that off and check the plastic hose for cracks...
Old Dec 20, 2009 | 10:18 PM
biz4two's Avatar
biz4two
Arrow
Def sounds like an IAC or vacuum leak. Good luck...
biz
Old Dec 21, 2009 | 08:39 AM
scraprat's Avatar
scraprat
Top Answer: 5
Have you disconnected the battery for awhile?
Old Dec 21, 2009 | 05:38 PM
Planenut99's Avatar
Planenut99
Thanks guys,
Sorry but I wasn't at work today and it looks like I have a broken roller to attend to tomorrow. I'll take a look at the vacuum lines you mentioned and let you know. Is there a cleaning procedure for the IAC?
Old Dec 22, 2009 | 12:27 AM
biz4two's Avatar
biz4two
Arrow
Take a look at my gallery (see link) for IAC info...
2003 Ford F250 4x4 - V10 IAC
When you remove it...you can clean it with MAF sensor cleaner or carb cleaner. Just be careful and let it dry complete before reinstalling. You prob going to need a new gasket too.
IMO...if you are going this route, then just replace it. This is not a high price item...
Good luck...
biz
