Frame switch
Old Apr 13, 2000 | 10:59 PM
CBs63's Avatar
CBs63
Frame switch
I have a 63 F100 witha 64-66 styleside short bed. I would like to find out what year of ford truck I can switch it all over to so I can get the newer brakes front end and steering?
Cliff
Old Apr 14, 2000 | 04:20 AM
jowilker's Avatar
jowilker
Frame switch
CB are you looking for a frame to put your sheet meatal on, or did you ask a different question?
John
jowilker
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
Old Apr 14, 2000 | 04:24 AM
Nathan's Avatar
Nathan
Frame switch
I put a 62f100 w/64 bed on a 79F150 4x4 frame, but it was not a direct bolt on.
Nathan
nathan@triton.net
Old Apr 14, 2000 | 11:20 AM
CBs63's Avatar
CBs63
Frame switch
I want to switch my cab, front clip and bed and motor etc to a newer frame so I can enjoy poer steering, disc brakes, etc. Instead of cutting the front of my frame and putting a newer piece in.
Cliff
Old Apr 14, 2000 | 12:27 PM
jowilker's Avatar
jowilker
Frame switch
Ok Your sheetmetal should bolt onto a chassis through 65-72. The 73-79 frames are different, and although the horizontal measurements are the same from the rear cab mounts forward, there are some elevation differences. Your cab would not set the same with out modifications. If you have enough engineering jucies in your blood you could make those mods and have a nice ride. :-)
The rails have some different bends in them and the front cab mounts are lower. I had a 76 & 66 LWB Chassis on wheels & tires side by side for compairison, for the doubters.
John
jowilker
66 F100s
Old Apr 14, 2000 | 03:08 PM
3179crew's Avatar
3179crew
Frame switch
61-64 frames are almost perfectly straight from front to rear, all twin I-beam frames drop down below the cab. There is no direct bolt together swap, but if you fab. your own body mounts anything with the right wheel base could be used.
The floor is higher in 61-64 fords to clear the straight rails, thats why they have those cool steps inside the door.
L. Edmundson
31 crewcab
35 pick up
72 F-100 lowrider
79 F-150 crewcab (custom built)
Old Apr 14, 2000 | 10:02 PM
CBs63's Avatar
CBs63
Frame switch
Thanks thats what i was wanting to find out. I'm now going to start looking for a newer frame.
Cliff
Old Apr 15, 2000 | 10:57 PM
Nod's Avatar
Nod
Frame switch
