Overdrive control cable questions.
Old Dec 20, 2009 | 10:39 AM
turnrjr's Avatar
turnrjr
I bought a 3 spd od transmission from a 53 f100 and rebuilt it for my 54. I put it in the rolling chassis a couple weeks ago. I built a new bracket off the transmission side cover to replace the one that supports the clutch linkage as the old one had an egged out hole where the shoulder bolt goes. There was no clip on the old one to hold the od control cable so I am making one while it is still easy to get at. Do any of you guys have one of these trannies? A photo of the clip mount and location would be good. I know it's a tough place to photograph. Also, the cable seems very long. Where does it route around the motor? Where does it go through the firewall? Where under the dash does the T handle mount? Again, pictues would be good. I need the mount for the T handle if some one has one for sale.
Thanks, Bob
Old Dec 20, 2009 | 11:18 AM
4tl8ford's Avatar
4tl8ford
Borg Warner OD Manuals here (PDF): Deve's Antique Chevy Truck Restorations | Borg Warner 3-Speed Overdrive Index
Old Dec 20, 2009 | 11:45 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Cable too long? You have the Ford replacement cable, which is the same one Carpenter sells. Carpenter's catalog sez: Cut to length.
As original:
B3TZ7A650A .. O/D Cable (no length listed) / Fits: 1953 F100.
B6TZ7A650A .. O/D Cable 63 3/4" long / Fits: 1954/56 F100.
Ford later replaced both these cables with A9AZ7A650A which is 80 1/4" long.
This cable's original application: 1949/51 Passenger Cars. This replacement cable was also used on 1957/66 F100's. 1967/72 is different.
Old Dec 20, 2009 | 12:08 PM
Julies Cool F1's Avatar
Julies Cool F1
I had one and I found it a pretty simple arrangement. You just clamp it anywhere you can along the line of the cable as close to the lever as you can get it.
Two places I used to use were bolting the retainer (which will be a clamp type exactly the same as that that holds a manual choke cable on your carburetor - but more stout) under the top bolt that holds on the solenoid, or under the top back corner bolt holding on the side (shift) casing - depending on your routing direction. Be sure to use washers on both sides of the clamp base and lock washer under the bolt head.
Adjust the cable in the clamp for the correct length and position, then trim it. Be sure you have the cable pulled out (in the lock out position) when you measure it to trim it - other wise you will cut it too short.
Old Dec 21, 2009 | 04:30 AM
turnrjr's Avatar
turnrjr
I mocked up a clamp and placed it in proper alignment by welding an ear on the clutch release support. The concern I have is the cable extends into the area where the shifting arms come out of the transmission and touches one. Then I tried going under the bell housing / between the cross member but alignment wasn't as good.
Regarding the length, Bill, I thought about shorting but it has a crimped mounting collar on the transmission end. Must be the new replacements come with it loose. I'll deal with that after the cab is mounted. Thank you.
Old Dec 21, 2009 | 01:34 PM
Julies Cool F1
You will have to use a two clamp set up then. The first one would be clamped somewhere up close to the bell housing and loop the cable upward. The second clamp - the one you fabricated will have to be taller and mounted at an angle so the cable can slightly "arc" above transmission and above the shift rods and shifters.
Also if all else fails, remove the lock out lever and install it upside down then re route the cable. That would mean you would pull out the cable to allow overdrive though rather than locking it.
Can you post a picture of your current set up?
Mother_Love
1978 - 1996 Big Bronco
Jan 20, 2017 10:04 AM
catneck
Jun 4, 2016 05:21 PM
mjricha.isu
Jul 9, 2015 07:41 AM
TRENT310
Oct 26, 2014 02:46 AM
mkmchu
Feb 23, 2014 01:29 PM
