Body question?
Old Dec 20, 2009 | 10:17 AM
SNSTER's Avatar
SNSTER
Body question?
short of cutting in the plate for the transfer case shifter a 1976 ford f-150 2wd body should fit on a 1977 f-250 4wd frame correct? both auto trans.
Old Dec 20, 2009 | 10:23 AM
freakboy's Avatar
freakboy
It should i dont see why it wouldnt.
Old Dec 20, 2009 | 11:36 AM
c.l.nye's Avatar
c.l.nye
yep thats what I did on mine.
Old Dec 20, 2009 | 01:22 PM
SNSTER's Avatar
SNSTER
I asked because I knew some frames from different years were different widths. After doing som research(should have done in the first place) this is what I have concluded. I have a 77.5 or later F-250 4x4 hence I have the wider frame. The earlier 4x4 250 had the narrow frame although the 2wd had a wider frame in the rear just as my truck does. so all should fit correctly. Someone correct me if I am wrong
Old Dec 20, 2009 | 02:19 PM
c.l.nye's Avatar
c.l.nye
the only cab as far as I know that WONT be a direct swap is a high boy.
Old Dec 20, 2009 | 02:24 PM
SNSTER's Avatar
SNSTER
I believe the cab would be a direct swap but a highboy bed would not as the frames in the front are the same but instead of widening four inches in the rear the highboys stay the same width
Old Dec 20, 2009 | 04:45 PM
peganit2's Avatar
peganit2
True, but you can drill new holes to put a highboy bed on it if you wind up with one.
I would rather not myself but if the right bed comes along for the right price, I could live with an extra set of holes. You can alwys weld them up anyway
Old Dec 20, 2009 | 08:26 PM
SNSTER's Avatar
SNSTER
also true. I too am trying to avoid that lol
