Dana 60
Old Dec 19, 2009 | 09:16 PM
gman30's Avatar
gman30
Dana 60
I have a 85 ford f250 4x4 that i did the Dana 60 conversion. I need to make a track bar and drop bracket i was wondering what the lenght of the track bar was from the center of each bolt. Also any other tips would be great thanks
Old Dec 21, 2009 | 10:57 AM
alxsnmr's Avatar
alxsnmr
IIRC the track bar should parrellel the Steering tie rod and be nearly the same length as the Steering tie rod. Though I dont recall the track bar being employed by Ford on a solid front axle that was leaf sprung until just recently in manufacturing but I could be wrong...
Old Dec 21, 2009 | 06:59 PM
79Ford4x4's Avatar
79Ford4x4
I know the 87-97 F350's had a short trac-bar. Did you do a shackle reversal? If not then you definatly need a trac-bar. Try and keep it the same as the drag link
