Sponsored by: Innova
6 speaker impedance?
Old Dec 19, 2009 | 03:09 PM
tomhinds's Avatar
tomhinds
4wd Low
In a 2001 excursion there are 6 factory speakers all @ 4 ohm. What is the head unit reading if powering all 6? 1.3 ohm or 5.3. if rear door & rear speakers in parallel, then that is 2 ohm + 4 ohm front = 1.3 ohm. Or is it 3 4 ohm speakers in parallel = 5.3 ohm.
I have replaced front & rear door speakers with Bostons and noticed a large improvement. Currently I will use head unit to power them & have a JL W6 w/ JL 500.1 powering it.
My real question and what I am debating is whether to replace rear panel speakers w/ bostons or disconnect the stock, have only 4 speakers, and sent them more power.
Thanx in advance.
Old Dec 19, 2009 | 04:23 PM
ReAX's Avatar
ReAX
My first guess is the fronts channels are each, and the rear four are paralleled into two channels (right/Left). I say disconnect the rear most speakers, unless you care how it sounds from the back most seat, you shouldn't hear much difference in the drivers seat without them.
Old Dec 19, 2009 | 08:51 PM
tomhinds's Avatar
tomhinds
4wd Low
Thanx ReAX. I noted today that head unit at rated power has 1% THD. Ha! Sound is a lot better with new speaks & I have plenty of bass. To set it right will require an amp & nicer head unit.
Loved your truck. It has quite a pedigree. You will love moving to a 12" woof. I have a 12" W3 in a 1 cu.ft. sealed box w/ Orion HCCA 225 pushing half ohm = 400W in a Impala SS and the bass is intensely tight.
Old Dec 19, 2009 | 08:56 PM
ReAX's Avatar
ReAX
You probably knew me from the SS world then (particularly the 94-6 Impala SS world as I ran NAISSO for a few years) too. Thanks for the encouragement.
Old Dec 20, 2009 | 05:55 AM
tomhinds's Avatar
tomhinds
4wd Low
Now that you mention it..... I love my '95 SS. NAISSO is a great forum. Mine is currently retired and sits most of the time. I always get a thrill when I am home and get to run it. It needs a little body work and a paint job. Drive train is A OK. Put LT2 heads on not too long ago and it pulls you back even better than before. It has old school Orion amps using stock head unit. Best sounding system I have ever had. Polk 6x9, rockford 6" in door w/ blaupunkt tweets on dash w/ silicone. Love my 7.3 Extinction as well and am trying to have a decent system w/o too much cash outlay.
Thanx for the advice and I plan to disconnect rear fill as you suggested.
