hpop question
Old Dec 19, 2009 | 01:57 PM
TTFord07's Avatar
TTFord07
Question hpop question
I installed an adrenalin hpop on my 2000 psd and decided i wanted to keep my old pump, can i put it on a 94-97 psd? isnt that supose to be a really good upgrade, my other question is if i can put that pump on do i have to install the check valves back or can i leave them out?
Old Dec 19, 2009 | 05:29 PM
95_Dually's Avatar
95_Dually
The pump from the 2000 will work. It is a 17* and it is an improvement over the factory 15* pump. I am not sure of the check valves. I would assume you would need to use the same parts as before. WAG.
Old Dec 20, 2009 | 11:30 AM
plowhand's Avatar
plowhand
Playing in the Dirt
You can use your 2000 pump on any 96-97 PSD but not on a 95 PSD. As Dually said it's an upgrade for a 96-97. The 96-97 have the anti-drain back valve in the pump but the 95 has it in the HPOP reservior. You will have to reinstall the check valves under the oil line fittings because they help equalize the pressure to both heads. On the Adrenalin, Bill reworked the insides of the pump so that they are not needed.
Ezalycasaid
35
Sep 10, 2016 05:29 PM
Rob Carpent
Jun 7, 2014 10:05 PM
Jesser02EX
Mar 20, 2014 11:20 PM
Rhager
May 8, 2013 09:15 AM
Cecil_Stringer
Dec 22, 2010 03:37 PM
