Sponsored by: Real Truck
where can i get an engine pre heater ??
Old Dec 18, 2009 | 01:08 PM
clyde2467's Avatar
clyde2467
hi
where can i get a engine preheater for my 1999 f350 superduty with a 7.3 diesel 4x4 can find anything in the uk, can any body help ??
regards kev
Old Dec 18, 2009 | 01:18 PM
Bumpkis's Avatar
Bumpkis
Finding one in the U.S. is not a big problem. I imagine you will have to find some type of converter due to the electrical difference.
Accessory Lookup
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Old Dec 18, 2009 | 01:19 PM
Bumpkis's Avatar
Bumpkis
Sorry, new to this place. The link shrank after my post. The "Accessory Lookup" is a link to a page with block heaters.
Old Dec 18, 2009 | 01:59 PM
bill64's Avatar
bill64
years ago i had one that was plummed into a heater hose, warmed and circulated the coolant, it worked well but cannot remember where i bought it, can also get the type that inserts into a freeze plug. my '94 has the freeze plug type right from the assembly line but i liked the aftermarket coolant heater better, seemed to work better, also easier to install. anyways i hooked them up to an outside electrical timer timed to go on about three hours before starting the truck.
now, not owning a diesel, i just get the highest cca battery and use a remote start. if i had a diesel i would probably want to preheat it as well, try googling block heaters and look for the type that circulates coolant, a very easy install
Old Dec 18, 2009 | 04:07 PM
mhoefer's Avatar
mhoefer
I think you want a block heater and it probably already has one, you just need to find the cord. In some cases the heater is there, but you need a different wire to plug into the block plug to run to your wall outlet.
ford 4.9 300
3.8 & 4.2L V6
Jan 24, 2015 12:24 PM
engine14
Mar 27, 2014 02:16 PM
90F250351
Oct 7, 2012 08:13 PM
skinsey
Modular V8 (4.6L, 5.4L)
Jul 30, 2010 03:02 AM
Defcon888
Sep 2, 2007 10:45 PM
