U joints
Old Dec 17, 2009 | 07:16 PM
Action4478's Avatar
Action4478
U joints
I tried this in the correct forum , now I will try it here :
I have a 90's model ford LGT 18 garden tractor ,the drive shaft from the motor to the rear axle needs U Joints . Small 1/2 Inch roller bearing pin & block type . I haven't had much luck finding a vendor ,& the dealer has the shaft , ($ 525.00) but no repair parts for it . Any help would be appreciated ...
Riiiiiiiiick.....
Old Dec 17, 2009 | 07:35 PM
Copedawg's Avatar
Copedawg
Look around in here: Ford Parts - Ford Tractor Parts
Old Dec 17, 2009 | 07:51 PM
Copedawg's Avatar
Copedawg
I looked around riiiiiiiiiiick but I didn't see it. Maybe they call it something else or maybe you can call them and get some insight
Old Dec 17, 2009 | 07:57 PM
70sfordguy's Avatar
70sfordguy
Try these
Belden Universal
Old Dec 17, 2009 | 11:42 PM
svcguy's Avatar
svcguy
Trailering
Universals
Try a driveline specialist. In Western Canada, we use Pat's Driveline (B.C. and Alberta). Most U-joints are standard to something, either vehicle or farm equipment. Most driveline specialists can identify u-joints by sight.
Old Dec 18, 2009 | 08:08 AM
Action4478's Avatar
Action4478
Thanks guys , I did get a link or two from the other guys also ...
Old Dec 18, 2009 | 08:21 AM
RRranch's Avatar
RRranch
I just tried the vendor I use, messicks.com. The shaft assy is 588 from them. Personally I would rebuild it or have it rebuilt. You must have a driveshaft shop around you somewhere. We have three of them in my town. If you can't find one then let me know and I can find you a phone number for one here. It will cost a small fraction of that here to rebuild it.
Old Dec 18, 2009 | 08:36 AM
Action4478's Avatar
Action4478
.. Thanks ...Shops here want to cut the ends off & use a larger joint , the shaft is square & has to has a square hole in the end to be able to install it , if worse comes to worse I'll make the blocks & the pins & I have a place to get the bearing caps . I would seem to me that someone would sell the joint as an assembly.(much easier) . the joints look about the size of a steering column joint ...
Old Dec 18, 2009 | 08:40 AM
RRranch's Avatar
RRranch
I'll bet they are the same. I was just looking at mine and thought mine is a lot newer it is the same as a steering shaft.
