Yet another 4X4 question
Old Dec 17, 2009 | 06:44 PM
Mid_Mo_F100's Avatar
Mid_Mo_F100
My problem is a little different, It will go into 4 hi, but when I try to go into 4 lo, it pops out of 4wd altogether (light goes out) and will not go back into 4wd until I shut the truck off and restart it. It has ESOF, no vacuum leaks that I am aware of. Any thoughts?
Old Dec 17, 2009 | 07:05 PM
zx250's Avatar
zx250
Of the next Riffraff East
Check you shift motor(topside of transfer case) and make sure it's not loose.
Old Dec 17, 2009 | 07:32 PM
big poppa's Avatar
big poppa
When going from 4 high to 4 low you are putting the trans in nuetral then switching to 4 low right?? Do the same thing putting it in 4 high.
Old Dec 17, 2009 | 07:44 PM
CPUNeck's Avatar
CPUNeck
I'd try new Hi-Lo and Lo-Hi relays, (they're just standard, 30amp automotive relays.) I just replace mine once a year after having this happen a couple hears ago.
Old Dec 17, 2009 | 08:46 PM
Mid_Mo_F100
Everything seems tight
Yes, I always do it in neutral. It will "clunk" like it is going into 4 low, but then instantly pops out and I lose everything. One time today it stayed in 4 low for about 10 feet and then popped out. The low range light never comes on either.
I will look into that, thanks.
Old Dec 20, 2009 | 07:14 AM
Mid_Mo_F100
Replace relays and still no go, anyone else have any suggestions? I'm lost!
