sadly, the wreath isnt hooked up :-( i want to hook it up though! and i want to make it so its easy to take on and off so i can put it on every year. but im no electrician!
its pretty simple..looks like you have a winch up front..all you need is 2 wires and a switch...also you need a step down from 110v to 12v which i think a resistor can do..
put the resistor in the middle of the + wire. and a switch inside or even outside. then just a negative.
to get even fancier connect it so when ur parking lights come on the reef comes on lol
If there is a electrical whizz on here, can you post up how that could be done on our rigs so that it works with the parking lights? That would be really cool!
yes yes i want it to come on with the lights, the wreath is attached to an extension cord in the picture:-P i cheated. i have a CM friend coming over to change the fuel filter on kevins toyota i may ask him if he can think something up.
just run a switch to it..or find the parking light wire:
have a multimeter with you set it so u can see volts. you need to find the wire that shows volts when u turn ur light switch. touch each wire and see turn on and see if it reads like 12v, if it dosent repeat till you find the wire..
or you could even tap in to the end of the parking light harness
