Sponsored by: Real Truck
lockout issues
Old Dec 17, 2009 | 08:36 AM
04 F-250 super duty's Avatar
04 F-250 super duty
lockout issues
Hey has anyone ever had issues where the drivers side lockout keeps coming apart, it happened with the factory one and I then replaced them with warn replacements and the same thing happens! The first few times it happened it was just under normal driving, and it wouldn't last more than a few hundred miles so I pulled the hub assembly apart and found a seized up u-joint.I replaced that along with the hub assembly while it was apart, and it was fine for about 20,000 miles. Now having to finally use 4 wheel drive it happened again any ideas from anyone should I try greasing them more? I havent added any just took them out of the box and installed them.
THANKS
