balance
Old Dec 17, 2009 | 08:28 AM
chilsam's Avatar
chilsam
Question balance
If I run 84 ext bal 12"&13" 460 flywheel on 74 460 int bal crank do I need to use 84 ext bal timing chain spacer "weighted" to have assembly in balance? THANX!!!
Old Dec 17, 2009 | 06:28 PM
Roger Carter's Avatar
Roger Carter
You can't "mix and match" parts when dealing with engine balance, without re-balancing the engine, or putting up with shortened engine life and vibration. The "later" spacer and flywheel are only part of the balanced assembly.
You can take the '84 flywheel and have it balanced to the specs for a '74 and then swap the flywheels. There would be no need to use the '84 weighted spacer if you had the flywheel re-balanced.
Roger Carter
