Wird wheel question
Old Dec 17, 2009 | 01:10 AM
low and fast's Avatar
low and fast
Wird wheel question
Hi! maybe a wird question but can i use hot rod (old style) wheel cover on my weld racing alu rims? Thanks Simson.
Old Dec 17, 2009 | 01:18 AM
c.f.moore's Avatar
c.f.moore
Probably not. Most aluminum rims have a smaller diameter inner lip (aluminum is thicker than steel), than a comparable steel rim. You might be able to force the wheel cover into the aluminum rim, but the clips will gouge the aluminum terribly and may not hold secure enough to handle road usage.
Find some steel rims of the correct size. You aluminum rims will thank you and you won't be trying to replace missing wheel covers.
Good luck
