2002 ford ranger 4x4
Old 12-15-2009, 08:17 PM
mattcomparato's Avatar
mattcomparato
mattcomparato is offline
i have a 2002 ford ranger 4x4,4.0v6. i am having problems with 4wheel drive.its like theres no power to the switch at all. the fuse is good on bothe sides.mechanical wise it worked great,just lost all power at once
Old 12-15-2009, 10:04 PM
Areyouforcereal?'s Avatar
Areyouforcereal?
Areyouforcereal? is offline
Check the shift motor on the t-case. They seam to be a common problem.
Old 12-16-2009, 06:36 PM
Rockledge's Avatar
Rockledge
Rockledge is offline
The 2002 Ranger 4x4 system relies on several different electrical components. As such, there are several fuses you need to confirm are good:
Battery junction box (underhood) fuse#:
1 (50A)
3 (50A)
13 (20A)
30 (10A)
Central junction box (inside cab) fuse#:
28 (7.5A) (manual transmission)
10 (7.5A)
11 (7.5A)
5 (15A)
And as noted, it could also be a TC motor issue.
remhaust
11-01-2016 11:40 AM
harleyrider13
New Member Introductions
12-25-2015 08:28 PM
2002exPSD
11-09-2012 08:44 PM
nikko
02-17-2004 10:06 PM
Quick Reply: 2002 ford ranger 4x4
