rear hub issues
Old Dec 15, 2009 | 08:47 PM
kgkleader's Avatar
kgkleader
rear hub issues
i have a dana 60 and i cant seem to find the rear end anywhere. anyone know interchangeability of hubs? my hub needs replaced and i just cant stumble across any dana 60 rear ends. is the dana 60 label only on the top right corner of the pumpkin or do they have the metal stamped labels on the left side also?
Heres the dmg
thats a wheel bearing
the inside race of wheel bearing still on the spindle
got if off by grinding/chiseling
Old Dec 15, 2009 | 09:39 PM
Fordworth's Avatar
Fordworth
That should be an easy find at wrecking yard. I would bring the bad one in and try to match it up since they often have loose ones piled up.
Did you clean everything really well or was the damage because the rear end was out of oil?
Old Dec 15, 2009 | 09:49 PM
kgkleader's Avatar
kgkleader
seal went out on other side and this side lacked all the oil. i got all new brake parts in it and seals/bearings just got to get the hub for that side.
No More Raptor
82
Sep 12, 2013 08:06 PM
hivoltj
Oct 26, 2012 05:45 PM
GwarForAll1021
2004 - 2008 F150
May 4, 2009 07:55 PM
