97 f350 351 wont turn over/or start
Alright so my dad has a 1997 F350 351 crewcab that wont start... after diagnois I was almost positive it was the starter so i replaced it with a rebuilt one
After Replacing the starter It still wouldnt start, still made the same tick noise that it did before
so beliving that the starter was orignally bad but the truck still wont start I replaced the solinoid that is on the passanger side fender
After the replacement of the solinoid It still wont start!!!
Starting to get frusturated and we Have 20 below wind chill in southern wisconsin today so Not the most pleasent thing in the world!!!!
Feel free to shoot out some options!!
thanks
thanks
You have one large cable and one small wire that connects on the starter, correct?? The large cable should be live with plenty of voltage at all times. The small wire should only be live with the ignition key in the start position. Trace everything backwards from there.
It may just be dirty battery cable connections or a bad ground connection. A bad cable or a bad battery that seems good.
There's a good chance it's your battery cables. When the plastic that covers them is subject to extreme changes in temperatures, it will crack and dry out like any other plastic. This allows water to seep in and cause corrosion, especially in climates where salt is used on the roads. When the cables get corroded, they can't carry the current they're supposed to and the starter isn't getting enough energy to turn over.
Ok I got the truck running
and like it always seems to be It was womething simple
the small wire going to the solinoid on the started poped off when i was installing the new starter so when the key was turned it wasnt engaging... so i reattached the wires and it fired right up
I aprieciate the help and im glad that i am a member of this fourm
you guys are a wealth of information
rickpilgrim
11-20-2012 12:07 AM
