1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Disabling interior lights/running board lights
Old 12-15-2009, 01:39 PM
cecilt's Avatar
cecilt
cecilt is offline
When we camp we like to leave a door or the hatch open and sometimes for quite a while. One thing I noticed after getting the '00 Expy in October is the interior lights and RB lights will stay illuminated if this is done. Is the only solution to pull a fuse? I can't beleive there is no switch to turn these off. I'm sure many of a batteries have succummed to this horrible design. tks
Old 12-15-2009, 06:06 PM
alloro's Avatar
alloro
alloro is online now
Received 4,217 Likes on 2,447 Posts
Have you tried turning the dimmer on the dash down all the way to see if it clicks and turns the interior lights off?
Old 12-15-2009, 07:28 PM
madsonp's Avatar
madsonp
madsonp is offline
From your owners manual:
The inside lights will not turn off if:
• they have been turned on with the dimmer control or
• any door is open.
The battery save feature will turn off the interior lights 45 minutes after the last door is closed, even if the dimmer control is on.
The only way to turn these off short of yanking all the wires, is either wait 45 minutes for the battery save feature to kick in, or pull the fuse. If you don't have your owners manual, it can be found here which will show you the particular fuse and location. https://www.fleet.ford.com/maintenan...ls/results.asp I agree with you, not a very good design.
Old 12-15-2009, 09:25 PM
cds's Avatar
cds
cds is offline
Somewhere on here is a thread on how to install a toggle switch to turn off the lights. I agree that someone dropped the ball on the design. Until I finally install my switch I found you can leave the back glass open and push the latch closed with your finger. Just remember to turn the handle and release it before you try to close it...I can only imagine how much the glass costs!!
jhcorley
08-25-2020 06:49 AM
Chargerkid
07-21-2017 07:14 AM
zippi
1947 and Older Ford Trucks
03-24-2017 09:17 AM
191124x7
2017+ Super Duty
02-10-2017 09:07 AM
quentinorciuch
01-12-2016 07:44 AM
Quick Reply: Disabling interior lights/running board lights
