Will the distributor from a SD EFI 460 be able to fire a MAF conversion?
I have searched histories on this topic and nobody has adressed this point. For the computer to fire the injectors sequentialy it needs to know where
#1 cyl is so it can fire injectors accordingly. Looking on a part supliers web
site they show the same dist for all years of efi, but for '97 only there is a crank sensor listed, this is not listed for any previous years.
Is this crank sensor for SEFI? If so then the dist is just for ignition, yes/no?
Also is there a way to mount a VSS on a 1978 Bronco?
There is a speed sensor for the factory cruise control, will this work?
(mounts inline speedo cable)
