engine swap
Old Apr 23, 2000 | 12:41 PM
t16's Avatar
t16
engine swap
hi, this is a goood web site. i have a 1975 f-250 4wd with a 390 and a c-6 auto tranny. it gets 9 mpg with a load or without. i am thinking about putting a rebuilt 300 in it for gas mileage. can anyone advise the plur and minus of this? that should **** off some purists. also what aftermarket fuel injection source does any one like? this is a cherry old truck and worth the hassles. better than a 30000 dollar new 3/4 ton truck. thanks from camas wa. twr
Old Apr 23, 2000 | 01:10 PM
Nathan's Avatar
Nathan
engine swap
You'd be spending an awful lot of gass money installing that 300. Engine mounts, throttle linkage, radiator, transmission, yadda, yadda,....
Nathan
Old Apr 23, 2000 | 01:43 PM
jowilker's Avatar
jowilker
engine swap
t16, your problem is 4X4 setup. You most likely have short gears in the rears. You need taller gears and bigger tires, that will slow the engine rpms down say at 60 mph. 3/4 ton 4X4s just weren't built to be economical.
Put your engine in a 2X4 with 2.75 rears and it should get 16 - 18 mpg.
Sorry but it's just the beast in it, just think about how good it pulls. :-)
John
jowilker
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
Old Apr 23, 2000 | 10:29 PM
DAV1972's Avatar
DAV1972
engine swap
On a personal note: I would more likely notice and admire your '75 4X4 than a 30,000 newer model.
Old Apr 29, 2000 | 12:22 PM
Trail_Rider's Avatar
Trail_Rider
engine swap
I have to disagree with Jowilker on the 4x4 setup. My 73 f100 w/390/4 speed 2wd only got around 10 mpg loaded or emty. That sounds like typical 390 mileage to me
Trail Rider
Old Apr 29, 2000 | 01:16 PM
jowilker's Avatar
jowilker
engine swap
TR did you have 2.75 rears behind your 390??
John
jowilker
66 F100s
Old Apr 29, 2000 | 02:44 PM
77 steve's Avatar
77 steve
engine swap
I agree it's hard to complain if you get 9-12 mpg with a 360 or a 390. Loaded or unloaded ! Auto or manual tranny.
77 steve's Avatar
77 steve
engine swap
Old Apr 30, 2000 | 09:15 AM
wnelson's Avatar
wnelson
engine swap
I'm not a fan of 390's but if the motor is in good shape, why bother to change it? I have owned Ford pickups with every thing from a 240 six to a 460 V8 and they all got right around 10 mpg so changing your motor would be a major expense for very little,if any, gain in mileage. If you want better gas mileage try changing gears or adding an overdrive unit.
Old Apr 30, 2000 | 04:16 PM
Trail_Rider
engine swap
No, Mine had 3:08's.
Trail Rider
Old May 3, 2000 | 10:04 PM
FE427TP's Avatar
FE427TP
engine swap
T16 I live near Camas and just went through the hassle of changing my 68 F100 Shortbox from a straight six to a 360, it was hard at some points, but not impossible by any means. I think just re-build the 390 with a good economical cam and performer intake and your better off, I get around 6 in town, but I think I've got 11 on the highway, but it has 4.10's and a posi in a Dana 60, it's kinda odd, a truck that was originally a 240 straight six with a 4 speed and 4.10's and a posi
Old May 4, 2000 | 09:07 PM
390GT's Avatar
390GT
engine swap
Wnelson wrote "not a fan of 390\s"
tisk tisk tisk.
i'm dropping a GT into a mav/comet.
then ppl will be jealous of the old FE
Old May 7, 2000 | 02:10 AM
omnipotant1's Avatar
omnipotant1
engine swap
The 390 in the trucks has a realy low compression ratio. I have a 75 F-250 2w/d Camper special with 3.71-1 gears. I rebuilt the engine with a 9.0-1 ratio and a small R.V. cam. It was huge improvement in milage and power and will still run regular gas (except when towing).
After the rebuild it was getting about 14 mpg. I then changed the stock holly 4 bbl. for a 600 cfm edelbrock carb. It now gets 15 to 16 on the open highway. Around town it's much less, but that's cause it forces me to hot rod it! (must be related to christine).
The 390 is an excelent motor. But it was designed for higher compression than 7.somthing-1. You could mill the heads if you don't want to rebuild right now.
Old May 7, 2000 | 04:56 AM
jowilker's Avatar
jowilker
engine swap
What was the ratio before you rebuilt it?
John
jowilker
66 F100s
Old May 7, 2000 | 07:02 PM
80f3504x4's Avatar
80f3504x4
engine swap
Actually in certain circumstances a 300 six might not get better gas mileage. With that heavy of a vehicle (assuming its probaly a highboy)it might work the 300 straight to death causing it to get worse gas mileage. Maybe not as bad as the 390 but not to far from it. I say this, my dad used to have Dodge W100 with a 318 (i know i know everbody gets wiser with age, he now has a ford)it had 3.23 gears and it got 8-10 mpg. The high gears were just working it to death(surprise) and lugging it.
