Fuel Pump issues
Old Dec 14, 2009 | 07:23 PM
tfulk2's Avatar
tfulk2
Fuel Pump issues
I have searched the previous threads and tried some of the solutions, but I still have my problem.
1992 f150 5.8 with one fuel tank
The truck would not start with the ignition switch, but we could start it from the solenoid. Replaced the ignition switch and the ignition part under the steering wheel. THe truck would still not start with the key. Next morning the truck would start with key. Pulled truck into the garage and shut it off. Come back later and the fuel pump would not run.
Fuel pump will run but has no power at it. Do not seem to have any power at the inertia switch. We have checked all the fuses and the relays.
I tried to jump the #2 position with the #6 position on the eec test plug. Nothing happened, and now the check engine light no longer comes on when in the run position.
Please help
Terry
Old Dec 14, 2009 | 08:03 PM
subford's Avatar
subford
Does the PCM Power relay click when you turn on the key?
Old Dec 14, 2009 | 08:07 PM
tfulk2's Avatar
tfulk2
it did earlier, but i dont know now after the cel quit. The relay was warm to the touch as well. if that means anything.
Old Dec 14, 2009 | 09:26 PM
tfulk2's Avatar
tfulk2
btt please
Old Dec 15, 2009 | 07:04 AM
subford's Avatar
subford
Originally Posted by tfulk2
btt please
Old Dec 15, 2009 | 09:29 AM
tfulk2's Avatar
tfulk2
Sorry that stands for back to top. It is used to keep your message at the top of the list. I apologize if that is not acceptable on this forum.
I will check for the clicking noise on the relay today.
Thanks for your help!
Terry
Old Dec 15, 2009 | 03:43 PM
tfulk2's Avatar
tfulk2
The pcm diode clicks, but the relay does not.
Terry
Old Dec 15, 2009 | 05:51 PM
tfulk2's Avatar
tfulk2
I replaced the pcm relay and my cel came back on. I hear a click when turning on the ignition and 2 seconds later another click. I now have 11.4 v at the inertia switch now but no fuel pump. I tested the inertia switch for continuity and it has it so the switch should be closed.
Thanks
Terry
Old Dec 15, 2009 | 08:04 PM
subford's Avatar
subford
Check the power at the inertia switch with a test light, a meter does not work well in this circuit.
If the test light lights check the and make sure the jumper for the fuel selector switch is in good up by the headlight switch.
If the jumper is good check at the plug going to the tank at the frame with the test light to see if you have power on the two power wires for the pump with a test light.
The wires are the brown wire with a white stripe and the orange ground wire.
If the test light lights at the plug then I would say you have a bad pump.
Old Dec 17, 2009 | 10:43 PM
tfulk2's Avatar
tfulk2
Thanks for the help! It was the fuel pump switch next to the headlight switch.
