code reader
Old Dec 13, 2009 | 10:14 PM
btm991's Avatar
btm991
code reader
what is good code reader for a 2007 6.0.
Old Dec 14, 2009 | 01:21 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
What do you want out of a code reader? If it's simply to "read" the stored codes and be able to erase them, get what I did.... Found on ebay the INNOVA Model 3130. Inexpensive and tells a lot for your 6.0.
If you want a computer (laptop) diagnostic SYSTEM, hold on and others will be by with their ideas.
Old Dec 14, 2009 | 05:06 PM
dcaddi2's Avatar
dcaddi2
...for that I think the Autoenginuity software gives you the most for relatively low cost.
It's not a dealer computer, but it is truly impressive.
Old Dec 14, 2009 | 08:54 PM
btm991's Avatar
btm991
if you erase codes wont they just come back up eventually
Old Dec 14, 2009 | 08:55 PM
btm991's Avatar
btm991
what would a autoenginuity cost
Old Dec 14, 2009 | 10:34 PM
spinge's Avatar
spinge
This is autoenginuity's web site. I am happy with mine. You can buy direct or look for deals around the web.
AutoEnginuity® - OBD2 Scan Tool - Professional PC and PDA Diagnostics
Old Dec 14, 2009 | 10:46 PM
spinge's Avatar
spinge
Forgot - you need to get the enhanced Ford expansion as well as the base software. The truck is OBD-II compliant to a degree, but most of the sensors on the diesels need the enhanced software to read them right. That is the same reason that the $50 readed from the local auto parts store WON'T work.
Old Dec 14, 2009 | 11:12 PM
03pwrstrk's Avatar
03pwrstrk
I recently purchased the AE w/ford pkg , the software is pretty complex to utilize it fully I felt there should have been more ford specific instruction relating to our trucks and how to setup and use the package in realistic terms.Most capable for code reading though, when scanning my 03 6.0 it came up with an( instrument cluster short to ground) ,I'm thinking fog lite mod that I did , and it showed( idle speed control active),I'm thinking the hi idle mod I did.I thought it was pretty impressive.Oh one thing I cant figure out is how to program speedo no instruction on that?
Old Dec 15, 2009 | 12:21 AM
rotun's Avatar
rotun
Reads ***** rules!
Like I stated in this post...get the Tirepaq, it will read codes and take care of your RPM issue with 35" tires.
Old Dec 15, 2009 | 07:26 AM
texans's Avatar
texans
I just got my ae from clay at riff raff diesel for $329 with the ford enhancements
Old Dec 15, 2009 | 09:09 AM
gearloose1's Avatar
gearloose1
Can you tell me more about how you fix the instrument cluster shorted to ground error?
The tire size thing.. I thought you can just program that on the dash?
Old Dec 15, 2009 | 09:33 AM
rotun's Avatar
rotun
Reads ***** rules!
The Tirepaq can be found for around $150-$180, the dealer can reprogram for up to 35" tires. Tirepaq will do it as well as read codes.
Old Dec 15, 2009 | 10:17 AM
gearloose1's Avatar
gearloose1
If anyone wants to sell a used Autoengunity... let me know.
Old Dec 15, 2009 | 07:13 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
The only bummer with Tirepaq is it can't datalog, graph, run test or help you diagnose sensors. Also with the AE you can change your tires up to 40". The dealer can change your tire size but finding one that can figure out how to go larger than what came on it is few and far between.
Unless the OP only wants to do very basic stuff the AE is more bang for the buck, no matter where it is purchased. IMHO
Old Dec 15, 2009 | 07:14 PM
Riffraff Diesel
PREMIUM SPONSOR
If you need help on setting your tire size drop me a line, I am happy to walk you through it.
