Dana rear end Identification
Old May 17, 2000 | 07:58 AM
mike77f250's Avatar
mike77f250
I would like some help identifying the rear end in my 77 F-250. Can't read the numbers on the cover so I took the numbers right off the ring gear inside They are as follows
2-21-77 Dana 30360 B3D99X 41-10 575
I would greatly appreciate anyone telling me what all these numbers mean.
Mike
Old May 17, 2000 | 09:26 AM
Eddie's Avatar
Eddie
The only numbers I recognize are "41-10", which tells me it has 41 teeth on the ring, 10 on the pinion, 4.10-to-1 ratio.
Tell you what: Post the VIN code and the various codes off the data plate on the driver's door jamb, and I'll dig out my '78 service manual and see what I can find out.
Ed
Old May 17, 2000 | 10:50 AM
FE427TP's Avatar
FE427TP
my guess is it was made in 2-21-77
it's a Dana 60
4.10 ratio
but that's just a guess and I am not sure
Old May 17, 2000 | 04:25 PM
Phillip Guidry's Avatar
Phillip Guidry
>the rear end in my
>77 F-250. Can't
>cover so I took the
>gear inside They
>are as follows
> 2-21-77 Dana
>30360 B3D99X 41-10
>575
>mean.
> Mike
If you post the numbers from the axle tube ,which is a "bill of materials" number, I can give you detailed info on the entire axle including the individual Spicer #'s contained within the axle assy. This goes the same for front Dana axles.
Phillip
Old May 17, 2000 | 04:28 PM
Phillip Guidry
1978f-250
17
Feb 4, 2017 02:09 AM
Dirtyweekender77
Nov 10, 2013 07:51 PM
meangene21
Jan 5, 2011 03:42 PM
aironly
Oct 11, 2007 04:48 PM
77hb
Aug 22, 2005 09:57 AM
